(I’m really hesitant to make this topic – this is my third attempt in as many days – because it’s so hard to replicate or measure the following. I make this topic primarily to get help, not to blame, because the behaviour described below is annoying to me.)
When I type in a note, I every now and then experience lag (every 20 seconds or so). This is a noticeable lag (where I pressed the 2nd or 3rd key and the first hasn’t shown yet). I guess it to be one or two seconds.
On Obsidian 0.9.22, the CPU never goes below 10% as long as I type. It frequently spikes to 40% when I’m typing in a note (without me doing something ‘special’ like searching, creating a note, or even switching to a different note). Those spikes seem to coincidence with the lag I experience.
I have:
  • Spell check disabled.
  • No Markdown preview panel open for the same file I work on.
  • No editor panel open for the same file I work on.
  • No MathJax or tables in my notes.
  • No block references or code (iframe) in my notes.
I could not connect this behaviour to specific notes.
I think this behaviour started around 0.9.18 or 0.9.19. I’m not entirely sure due to the frequent releases during that time.
I would expect a relatively smooth typing experience.
A noticeable input lag every now and then. This latter seems to coincidence with the CPU spikes.
  • Operating system: Windows 7 64-bit
  • Obsidian version: 0.9.22
I have these plugins enabled:
  • File explorer
  • Search
  • Quick switcher
  • Backlinks
  • Starred
  • Command palette
  • Daily notes
  • Random note
  • Sync
(I have no third-party plugins active.)
Sounds like it’s doing something when it’s saving. Could you take a performance recording using the developer tools? Once that’s done, export the profile json file and put it into a .zip, then send it to me privately (preferably via DM on Discord).
I send the file through Discord. Thanks for your consideration. :slightly_smiling_face:
Licat’s analized your vault and it gave us ideas for further optimizations.
Thanks for the update, that is good news. :slightly_smiling_face: Let me know if I can help in some way.
we will introduce a structural change in 0.10.12 that could positively affect your issue
Thanks for the update and thanks for the good news. I’ll look forward to it. :slightly_smiling_face:
