Thanks for the reply!
Yes, I came across that MacOS thread while searching but it didn’t seem relevant.
And, for the sake of clarity, it wasn’t only the font size that had shrunk (e.g. in the editor/preview panes), it was the entire interface (i.e. menus, icons, status bar, etc). So, that being the case, your Ctrl+0 suggestion fixed everything! THANK YOU!
Absolutely NO idea how I managed that considering how many times I had to press Ctrl+- just to replicate the problem! I also can’t seem to find those settings in the list of hotkeys or the command palette. Is that more of a general electron thing? I noticed I can replicate it with VS Code too.
I’ll leave a couple of screenshots just in case any other newbies are having the same issue and need a visual. (I apologise in advance for my bright screens, but my office is very, very sunny!)
Thanks again!
Problem:
Reset with Ctrl+0:
