Obsidian window will not stay focused unless clicked directly (Mac)
I’m trying to use Command + Tab or open mission control and click on any Obsidian window so that I can use it. This used to work perfectly normally until a week or two ago. Now the window simply vanishes behind whatever app I was focused on before it. Then I need to manually move the other window out of the way and click on the Obsidian window or click it from the dock. Obsidian is the only app on my computer that this happens with, which is why I think it’s an Obsidian-specific problem.
I made sure there was nothing hogging up CPU or memory by checking the Activity Monitor while Obsidian is open.
If it’s relevant, I’m running Sequoia 15.6.1 on a Macbook Air, M1 chip from 2020.
