I’ve got a weird problem where sometimes when I start to type a heading in Obsidian (one or more # followed by a space) the Obsidian window just goes blank. It’s definitely happened on my Mac, and maybe on Windows though I cannot remember for sure. It’s happened half a dozen times now.
To recover I have to quit and restart Obsidian. Sometimes the heading I was typing is gone, so Obsidian did not save the last few characters I typed.
I suspect it may be something like a plugin crashing, but I don’t know how to troubleshoot it. The last time it happened I tried selecting the View > Toggle Developer Tools in the menu, but nothing happened – the screen stayed blank.
I’m just wondering, the next time this happens what can I do to collect more information and find out what is causing it?
I have done the Rebuild vault cache, to see if that helps.
In the meantime, debug information is as follows:
Obsidian version: v1.11.5
Installer version: v1.8.3
Operating system: Darwin Kernel Version 25.2.0: Tue Nov 18 21:09:40 PST 2025; root:xnu-12377.61.12~1/RELEASE_ARM64_T6000 25.2.0
Language: en-GB
Catalyst license: insider
Insider build toggle: on
Snippets enabled: 3
Plugins installed: 15
Plugins enabled: 13
1: Book Search v0.7.5
2: Linter v1.30.0
3: Dataview v0.5.68
4: Meta Bind v1.4.6
5: Omnisearch v1.28.0
6: Outliner v4.9.0
7: QuickAdd v2.9.4
8: Style Settings v1.0.9
9: Templater v2.17.0
10: Todoist Sync v2.5.0
11: Zoom v1.1.2
12: Excalidraw v2.19.2
13: Plugin Update Tracker v1.7.0
No need to file a bug report yet, but looking at your debug info I’d go to Settings > Community plugins > Restricted mode and click Turn on and reload. The issue is probably not from a snippet, but I’d disable those as well for testing.
If you don’t see the issue in Restricted mode, it’s coming from one of your plugins. Turn Restricted mode OFF (enabling community plugins), disable all the plugins individually, and restart. You don’t have that many so you can slowly turn one on at a time to see how it goes for a hour or so. No problem → enable another and so on.
