Obsidian Web Clipper + AI: Capture & Summarise Web Content (YouTube, Reddit, Books & More)
Today I’m going to show you how to capture and summarize web content using the Obsidian AI Tools and Web Clipper.
Join me as we set up and explore the Obsidian Web Clipper to transform your research and note-taking workflow.
CHAPTERS
00:00 - Intro
01:07 - Web Clipper Goal System Overview
02:14 - Web Clipper Showcase: Use Cases
03:48 - Web Clipping a YouTube Video
06:57 - Web Clipping a Blinkist Book
08:30 - Web Clipping a Reddit Post
10:20 - Web Clipping a Goodreads Article
11:35 - Web Clipping a ChatGPT Response
12:36 - Web Clipper Highlighter
14:30 - Obsidian Web Clipper {{variables}}
23:10 - Obsidian Web Clipper |filters
24:20 - How to Install & Configure the Web Clipper
26:13 - Setting up your Web Clipper AI Interpreter
31:46 - Setting up your first Web Clipper Templates
44:59 - Web Clipper Resources
The Youtube template is not working for me. I cannot import it givi g me error.
Hi Gandurian, sent you a direct message, let me know that one works
is it possible to change tags in the frontmatter using ai context?
I tried something like
  "schemaVersion": "0.1.0",
  "name": "Reddit Post",
  "behavior": "create",
  "noteContentFormat": "# [{{title}}]({{url}})\n\n> Posted in [/{{ url | split:\"/\" | slice:3,5 | join:\"/\" }}](https://old.reddit.com/{{ url | split:\"/\" | slice:3,5 | join:\"/\" }})\n\n{{\"You are a key point extractor and summarizer. Briefly summarize the discussion for the post. keep it short to one to two paragraphs. If you find any useful or relevant links blocks such as [some text](https://sometext.com) add them in the end under ## Links mentioned. Also create a list of relevant tags and add them as tags to the tags property in frontmatter\"}}\n",
  "properties": [
      "name": "url",
      "value": "{{url}}",
      "type": "text"
      "name": "title",
      "value": "{{title|trim}}",
      "type": "text"
      "name": "subreddit",
      "value": "{{ url | split:\\\"/\\\" | slice:3,5 | join:\\\"/\\\" }}",
      "type": "text"
      "name": "published",
      "value": "{{published|date:\\\"YYYY-MM-DDTHH:mm:ssZ\\\"}}",
      "type": "date"
      "name": "created",
      "value": "{{time|date:\\\"YYYY-MM-DDTHH:mm:ssZ\\\"}}",
      "type": "date"
      "name": "tags",
      "value": "#bookmarks, #reddit",
      "type": "multitext"
  "triggers": [
    "/^https:\\/\\/www.reddit.com\\/r\\/\\w+\\/comments/",
    "/^https:\\/\\/old.reddit.com\\/r\\/\\w+\\/comments/"
  "noteNameFormat": "{{date|date:YYYYMMDDHHmm}} – {{title|trim|safe_name}}",
  "path": "bookmarks",
  "context": "{{selectorHtml:.commentarea|markdown}}"
but it doesn’t work.
