Obsidian Web Clipper - Add to Obsidian not working
#webclipper
I’m using the recently released Obsidian Web Clipper in Chrome browser extension.
Obsidian Version 1.7.5 (Installer 1.4.14) and Chrome Version 130.0.6723.117 (Official Build) (arm64).
I use the default plugin for articles and Youtube template shared in GitHub - kepano/clipper-templates: Obsidian Web Clipper templates for various sites. · GitHub to try it out.
The Web Clipper interface populates with the header, properties and note content.
When I " add to Obsidian", the title gets created in Obsidian , but no properties and note content.
After multiple tries, one time it created the article , but if I do send it again from the web clipper, the title gets appended to title 2, but does not bring in the properties and note content.
This happens with the default and YT templates. I tried some community templates for Youtube with transcripts. I have the same issues.
Is there any setting in browser, ,which I have missed?
Is there any setting in Obsidian which allows creation of the note woith properties and note content,
This appears a bit strange considering that I’m running the MacOS and Chrome on the latest version.
Any suggestions?
@Pch
Note: The same happens with Safari browser as well.
You could try to update Obsidian’s installer :woman_shrugging: …
(This is the only suggestion I can make)
Thanks for your response. I installed the latest installer now.
  1. I clip an article using the default template. no changes except the path to the folder.
  2. the issue remains - only header is downloaded. no yaml and no content.
  3. the same results with youTube template. only header is downloaded. no yaml and no content.
  4. this is done in Chrome browser web clipper plugin.
    @Pch
Have you tried using a different browser? It’s best to stay away from closed-source browsers like Chrome and shady companies like Google. On the Chromium side, you could try Brave or the Firefox-based Zen Browser. These are freesoftware browsers.
I’ve been testing the clipper on Chrome, Arc and Safari (and very briefly on Firefox I think) without encountering such issues (and without having to touch the browser settings :woman_shrugging: (not that I can remember at least :innocent: )
Same thing happens for me, I use flatpak version of Obsidian (v1.7.5) and it doesn’t work with Brave but works with Librewolf.
I tried with Chrome and Safari. The details of the web article populates in the clipper settings but does to transfer in full to Obsidian.
Such a nice tool, but unable to use it.
it will be good if the author of web clipper can write down all dependencies which are essential to run this tool like : iOS , Obsidian, Chrome, safari versions and any settings which are essential.
I cannot understand how it works for one and not for another when the web clipper is a browser extension and I’m running on the latest browser versions on Chrome(Version 130.0.6723.117 (Official Build) (arm64)) and Safari (Version 18.0.1)
Obsidian current version: v1.7.5 Installer v1.7.5
Note: I have my inbox as 00 :inbox_tray: Inbox. Will this cause any issue while sending it to Obsidian from Web Clipper?
@Pch
I didn’t had much to do to make the Clipper work to be honest (on Mac, iPhone, iPad… and the various browsers I used to test the Clipper) :thinking:
It could be helpful if you could show where you’re stuck, more precisely …
I mean, on Mac (Big Sur & Sequoia 15.1), all I did for Chrome & Arc was installing the extension from the Chrome Web Store, enable it and give it the very few permissions it requires to be able to clip the content of a web page …
For Safari, on Mac, iPhone, iPad, I just downloaded the Safari extension from the App Store and enabled it …
For each browser, all I did then, in the settings of the extension, was adding a vault where the clippings should go (under the General section of the settings of the extensions) which you can access by clicking on the “cog” icon at the top right of the Clipper’s window :woman_shrugging: …
(This is from the Clipper on Arc using the default template :blush: )
After installing & enabling it on every browser, I might have reloaded/refreshed the webpage I wanted to clip (either using Cmd + R or Cmd + Shift + R) using the default template coming with the Clipper (at first)
I wouldn’t know :sweat_smile: …
I voluntarily don’t use emojis in the names of my folders/notes to avoid having to ask myself this precise question and potentially having to spend some time on find a workaround if there’s an issue :innocent:
Same on Linux, Firefox. Obsidian version 1.7.4, Web Clipper version 0.9.8.
The Save file and the Copy to clipboard options work tho.
Also with Obsidian version 1.7.7
Well, for Linux there was a solution:
Good news, I originally had the same problem as you, but then I upgraded from version 1.6.x to version 1.7.7 and the problem disappeared. Now clipping is done correctly.
My operating system is Windows 10, and I have tested Chrome and Edge as browsers, and they both work well. Good luck to you!
How exactly did you use this to fix the issue?
Yes. My Web Clipper also only creates a note with the title and no content.
The same is also happening for me when I use my iPad.
Well, I just made sure the obsidian.desktop file looks like this:
[Desktop Entry]
Categories=Office;
Comment=Obsidian
Exec=/usr/bin/obsidian %U
Icon=obsidian
MimeType=x-scheme-handler/obsidian;
Name=Obsidian
NoDisplay=false
Path=
StartupNotify=true
StartupWMClass=obsidian
Terminal=false
TerminalOptions=
Type=Application
X-KDE-SubstituteUID=false
X-KDE-Username=
I’m having the same problem, but might’ve figured out what we all have in common? Do others in this thread have vim keybindings enabled perchance?
As soon as I disabled those the plugin worked again. If this is what causes the problem for others in this thread please reply so I can open an issue on Github
I had a similar issue.
For me the issue turned out to be a rule in the Templater plugin to apply a template to the same folder that Webclipper was adding to – effectively overwriting all properties coming in from the webclipper.
My chrome extension works fine, but I had the same issue with Safari extension when using iPhone. It would only clip the article title to my vault.
Here’s how I fixed it:
  1. Clear Settings for Vault:
    • Open Safari app
    • Go to the clipper extension settings
    • Under “General settings”
    • Delete all entries under “Vaults” (my was showing object [Object])
  2. Update Permissions for Obsidian app:
    • Open Settings app
    • Go to Obsidian
    • Change “Paste from Other Apps” from “Ask” to “Allow”
