Also: I would like to place my vaults for the new version in a new place. Can I just copy+paste into new location? How do you manage your vaults together with different obsidian versions?
hi @coreSpotz, for the MCL part i think that was a bug after i included global settings for dataview/table/callout blocks. i’ve updated the snippets and merge to the main to support Obsidian 1.0.x. do download/update to the latest. let me know if that doesn’t resolve it.
Yes the wide-page class does work now. But I can’t say anything about the other two because as before the Contextual Typography plugin does sadly not work. Could it be that there is a third plugin required to have grid layouts with the classes provided in your package?
i use Contextual Typography plugin extensively in my personal theme. works well on my side. as for my snippet, only the wide-dataview and wide-table require that plugin because i need to identify the div.
Can u elaborate how the plugin doesn’t work on ur side. if u r referring to my snippet for the grid layout, those doesn’t require the plugin.
Also, per your example, i tested the yaml – it doesn’t properly recognize if u put semi colon cssClass: wide-page;. remove that or use coma ,
- item a
- item b
- item c
- item d
{.two-column-list-block}
For example, nothing happens to that list. (Yes I do remove the quotes )
Btw., your wide-page works just fine. Thank you very much once again for creating this css. I didn’t understand why Obsidian wouldn’t use 100% of the available space, especially when you’re working on a laptop.
