Create a code block or inline code and place a note title inside it:
Foo Bar
or Foo Bar
2. Go to the file “Foo Bar.md” in the “Unlinked Mentions” it shows the reference to the previous file and you can even try to link to it but since it is inside a code part it will never work.
Don’t show words in code blocks inside the unlinked mentions or show them but don’t give the option to link to them since that can break the code. Maybe show “Can’t link to code” or similar.
