Hi! I recently tried to download third-party plugins for the first time, but every time I try to download it via Obsidian, it tells me “failed to install (name of plugin)”. I’m not sure why it doesn’t work…
I live in North America, so I don’t think it’s a firewall issue.
Thank you in advance!
Does it happen to all plugins or only some?
All third-party plugins, yes. Just tried to download the top 10 and it didn’t work.
Can you access https://raw.githubusercontent.com/obsidianmd/obsidian-releases/master/community-plugins.json?
Yes, I can.
I’m out of ideas then, hope someone can help you!
Might help to check for console errors too:
To check for errors, first open the developer tools by pressing Ctrl-Shift-I on Windows/Linux or Cmd-Opt-I on macOS, and then go to the “Console” tab. If you want to save the error to a log file, you can right click on the error and choose “Save as…”.
Alright, I’ll take a look at that! Thank you for your help!
This appears when I try to download plugins, I’m not sure where I would need to save the error. I’m not super tech-savvy when it comes to things like this, oops.
In Settings - About, is your installer version low? Latest is at 0.11.5 now. Try downloading from obsidian.md again.
It works now! Can’t believe I didn’t think to update Obsidian, thank you!
