Obsidian Sync intermittently empties incoming notes on Android and does not recognize the diff
  1. Set conflict resolution to create conflict file on an Android and a laptop.
  2. Write a note on the laptop.
  3. Sync the note to the Android.
  4. Rename the note and edit it on the laptop.
  5. Sync the note to the Android.
Yes.
The note is synced with the new name and the latest content.
  • There was an empty note with the new name.
  • No conflict file is created.
  • The latest sync version history is the modification on the laptop.
  • The local history is just a empty note creation.
Since Obsidian does not recognize the diff, I could not restore the latest version. Instead, I restored the second latest version, then restored the latest version (which has become the non-latest in the history).
Android:
    Obsidian version: 1.12.7 (303)
    API version: 1.12.7
    Operating system: Android 13 (Sony XQ-BC42)
    Webview version: 146.0.7680.177
    Catalyst license: none
    Live preview: off
    Community theme: Minimal 8.1.7
    Snippets enabled: 4
    Plugins installed: 9
    Plugins enabled: 1
        1: Calendar v1.5.10
Laptop:
	Installer version: 1.12.7
	Operating system: #20~24.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Mar 19 01:28:37 UTC 2 6.17.0-20-generic
	Live preview: off
	Snippets enabled: 3
	Plugins installed: 8
	Plugins enabled: 8
		1: Calendar v1.5.10
		2: Definition List v0.2.5
		3: Linter v1.31.2
		4: Minimal Theme Settings v8.2.1
		5: Smart Typography v1.0.18
		6: Templater v2.18.1
		7: Typewriter Mode v1.3.1
		8: Unicode Search v0.7.3
Yes, this time it was a Debian package and I am aware of that it is not supported here; I encountered this issue many times with Windows PCs too.
  • It happens couple of times a month for two years.
  • No community plugins are enabled on the Android.
  • In the past, it happened with the Templater plugin and its folder templates enabled. The plugin inserted the template into the empty note, so Obsidian recognize the diff.
  • Always too late to notice it, I’m afraid I could not catch the Sync activity log at the time.
Screenshots:
I tried to reproduce it today and reproduced it with the following steps, with high probability:
  1. On the desktop, create 30 notes with the following commands or something:
    # In vault
    mkdir sync_test
    cd sync_test
    for i in $(seq -w 30); do echo "# Foobar $i" > "t_$i.md"; done
  2. Wait until the Sync icon turns green in the desktop app.
  3. Open the app on the Android.
  4. Wait until the Sync icon turns green in the Android app.
  5. Check 30 notes.
It seems like Sync is fine, somehow the app fails to read note contents. Nothing is changed by restarting the app; Restarting the device resolves the problem.
The network type does not seem to affect the probability; It is reproduced with either LTE or Wi-Fi.
The desktop:
	Installer version: 1.6.5
	Operating system: Windows 11 Home 10.0.26100
	Live preview: off
	Snippets enabled: 3
	Plugins enabled: 8
		1: Calendar v1.5.10
		3: Linter v1.31.2
The Android:
	API version: 1.12.7
	Live preview: off
	Plugins enabled: 0
At first, I thought this was a Sync issue but it turned out to be the file-reading issue. So I will close this issue and created a new one:
When newly created notes are synced, Android app fails to read their contents - Bug reports - Obsidian Forum
