Obsidian Sync intermittently disconnecting from remote vault on it's own
  • Install obsidian on Android pixel 6a
  • Connect obsidian sync and download vault
No. I contacted obsidian sync support and was told to create a new local vault and allow it to sync with that. I did and before I did that I also cleared all the app data and uninstalled and reinstalled the application.
I open the application and it maintains connection to the remote vault.
The remote vault is disconnected. There was no error indicating a disconnection. Prior to disconnection of the vault often obsidian re-indexes the entire vault. I have checked if those files have been modified by something else with the last modified time. They have not.
This also happens on the desktop application intermittently. I have zero community plugins enabled on the mobile application. Sometimes closing obsidian and opening it again after it re-indexes results in the vault re-connecting on its own, but not every time and less so with the mobile application.
Pixel 6a
This is often a sign that something cleared a place where obsidian stores data.
Are you using any app to “clean” unused space/clear cache something like that?
It’s better you keep the ticket open with the email support. It’s not clear if there is a bug/what is the bug here. Moved to help section for now.
No I am not using anything to clean space or clear cache. The ticket has been open for 11 days and I have spent hours trying to fix this issue and it seems like it is being dismissed.
I don’t understand how it wouldn’t be a bug. It is a fresh install and fresh vault. It disconnects on its own with no error message. No community plugins were installed on the mobile app. I am using obsidian sync and not some other syncing option. All other settings seem to be maintained other than the obsidian sync connection. It still has my login information, and I can re-connect with the remote vault. Restarting the application sometimes restores the connection. At minimum, it seems like a bug that there is no error reported when disconnection happens.
Do you mean that you need to redo the procedure to connect to a remote vault? Or simply that is not uploading files?
This is even more strange.
Where is this vault stored on your desktop and do you move your vault?
I don’t move my vault. It is two directories deep on my main hard drive.
I mean that it is no longer connected. I have to go into the plugin settings and click the connect button.
