For some reason whenever I use Obsidian now the app eventually changes to a black screen. I have to right click the app icon to close it (Windows 10 PRO). This worked fine for a few days, I would just close and reopen the app. Now whenever I close and reopen it my entire note contents will be deleted. Only the name on it remains. I’ve been able to recover the texts through snapshots file recovery but this is not a solution.
I’ve reverted to the default theme and stopped using chorme at the same time on the same screen. I make sure I have no background apps open (aside from chrome). I’m rather stumped here as I haven’t changed anything with my set up. I’m using Obsidian the same way I always have, it’s just not working properly anymore. I’m not sure what else to try, aside from keeping back ups.
Also, for your own vault, when something is acting odd, including using the default theme, it’s best to try in restricted mode (with a restart) as well.
I tested out the sandbox vault and it worked fine. I created a new vault and just copied my writing to it (I only had two notes so it was fast to do) and it’s been working well. I’ll update if there’s any problems, but it seems to be fine. Not sure what the issue was with my old vault, but at least it works now. Thanks!
