My desktop app is stuck at the main page after opening. It says obsidian in indexing the files synced using telegram sync plugin. Except for closing the app, none of the controls are working.
I uninstalled the plugin by deleting it from the storage. But still the problem persists
I don’t see anything in the screenshot related to that plugin (other than its startup time), but try moving the files synced using telegram sync out of the vault.
Yes, the screenshot doesn’t anything about it. But the problem started when I sent some files to using that plugin and now they are struggling to get indexed. I removed the plugin folder and its contents out of obsidian and now its been resolved. Thank you. It worked.
