Obsidian render code block into html format. Help!
Hi I am new in obsidian, and currently dont know how to render code in my page
when I type code as tutorial on internet
Obsidian after enter will render it to
try to copy code from outside with paste plain text having the same issue
please help me! Thanks
Find out the issue, I put markdown syntax inside a table so it doesnt work.
Highly appreciate if anyone know how to overcome this.
You could try putting the code elsewhere and embedding it in the table (if you need it to be in a table).
yes, it works thanks
