Obsidian Publish parses Bold/Italic differently than Desktop
Create a page with a bold italic item, using the following syntax:
_**Some Bold Line
Note that in the Obsidian editor, this line will appear bold and italic. When published, however, it will render as standard text with a “_**” before it.
Did you try the above steps in the sandbox vault (or just any vault started in restricted mode, no snippets and default theme)? Yes
I expect Published pages to show:
Some Text
The Published page shows:
_**Some Text
Obsidian version: v1.6.7
Installer version: v1.6.7
Operating system: Darwin Kernel Version 23.5.0: Wed May 1 20:12:58 PDT 2024; root:xnu-10063.121.3~5/RELEASE_ARM64_T6000 23.5.0
Catalyst license: none
Live preview: off
Publish:
Desktop
I don’t use Obsidian Publish but what happens if you write a “full” bold and italic sample text (i.e.: surrounded by an opening _** and closing **_) ? :thinking:
I mean, what happens if you use this:
_**Some Bold Line**_
instead of this:
_**Some Bold Line
Yes, when you close the bold and italic, they both render consistently.
It’s easy enough to work around, I just have to make sure I close my tags.
But Obsidian and Obsidian Publish should probably have a consistent behavior. Either they should both render the text as bold and italic, or both render it as incomplete.
What view are you using on desktop? (I’d expect Reading View to correspond to Publish; Live Preview sometimes has rendering quirks.)
Oh, fascinating.
Reading view does indeed show it as:
_**Some text
Edit view (non-source), however, renders it as
Some text
So, I guess I can check before uploading by toggling reading view. Edit and reading look so similar I never bother switching into Reading. Guess I’ll have to make that a habit.
Yes, you must close your tags. Source mode acts that way because it’s forward looking parser only.
