Obsidian Project Planner
Hello,
I’ve been building and designing an Obsidian Plugin inspired by Microsoft Premium Planner. For those of you familiar with Premium Planner, you’ll appreciate the familiar style, layout and features of Obsidian Project Planner.
Due to the amount of features and views, it is not practical to share everything. There are many features yet to be implemented. I will try to share as much of the current features as possible. If there’s interest in this plugin, I will share more details and provide a link to the GitHub repo.
Note: The features I’m sharing are fully working and the plugin is pretty stable even at the current development version. I use it almost daily to track tasks for the development of this plugin. (Also on my GitHub repo)
Featured Views:
  • Grid View
  • Board View (Kanban)
  • Timeline (Coming soon)
  • Dependency Graph
Global Plugin Features:
  • Multi-project support
  • Full sync between all views
  • Full drag and drop support for all views
  • Inline task editing in all views
  • Task dependencies
  • Due Date Overdue tag indicator
  • Quick complete task checkbox
  • Project Hub Page (Will become a dashboard)
  • Create and update notes for all tasks with the click of a button
  • Task Notes are fully integrated into Obsidian Graph
  • Customizable Statuses, Priorities and Tags
Grid View:
Grid View Highlights:
  • Tasks with subtasks
  • Right-click context menu functions just like Microsoft Planner:
    • Open details
    • Add New Task Above
    • Make Subtask
    • Promote to parent
    • Delete task
  • Task Options reveal on hover with the same options as above just like MS Planner
  • Adjustable column widths
  • Show/Hide columns
  • Search and sort tasks
Board View:
Board View Highlights:
  • Task Options icon reveal on hover like MS Planner
  • Right-click context menu:
    • Rename bucket
    • Add bucket to the right
    • Delete bucket
  • Drag and drop to reorder buckets
  • Add new bucket button
  • Show/Hide Completed tasks
  • New options and features coming soon
Task Details:
Task Details Panel
  • Look and feel similar to MS Planner (splits the current View as a new tab to the right)
  • Mark as Complete
  • Copy task link to add to notes or other tasks
  • Description is fully Markdown compatible (something MS Planner will never do)
  • Task dependencies:
    • Finnish-to-Start
    • Start-to-Start
    • Finnish-to-Finnish
    • Start-to-Finnish
  • Attachments currently only support internal/external links
  • Checklist with drag and drop sorting for checklist items
Plugin Settings
Plugin Setting Highlights:
  • Add and manage projects
  • Add and manage status, priorities and tags (labels)
  • Set default View
    • Grid View
    • Board View
    • Timeline View
  • Create/Manage Project Hub note/page
  • Create/Update Task Notes with task links
  • More features and settings on the way
    • Open views in the same tab or in a new tab
    • Drag and Drop Statuses, Priorities, Tags
It would be interesting to see how this develops and if it would be compatible with Task Notes.
Although I do like the idea of keeping this plugin completely self-contained, I do recognize the importance and convenience of integrating with other core and community plugins.
I have included in the plugin roadmap integration with Full Calendar and I am open to working with Task Notes as well. I’ve also considered integration with Reminders and To Do plugins.
I think offering the best of both worlds might be the solution. Including options and configurations in the plugin settings to work with popular plugins if desired.
I’ll be honest. If this plugin — or any similar one:
  1. works with data that is already in the YAML properties and
  2. lets the user choose the names of these properties,
it will be very interesting. If it doesn’t meet these two requirements, it will not be interesting, at least not to me.
Thanks for your comments. I will investigate YAML properties and I will see what I can do.
Brilliant plugin! I really hope you can release more details soon. If you ever set up a donation link, I’d be more than happy to support you!
+1 interest
+1 interest
New Updates
Interactive Dashboard
The Dashboard serves as the central project overview.
Dashboard Features
  • Show an individual project or Show all projects at the same time
  • Interactive Cards show related tasks:
  • Click on a task to view Task Details:
Updated Board View
New features added to the Board View including:
  • Customize the colour of a bucket
  • Assign bucket for a any task in the project:
New Timeline View
The new Timeline view (a.k.a. Gantt View) shows the timeline of your project.
Timeline Features
  • Customizable Task list (left side)
    • Behaves just like the task list in Grid View.
  • Interactive Gantt Chart
    • Draggable dates
    • Expand or decrease dates by dragging the left/right date handles
  • Zoom the timeline by Day, Week or Month
  • Go to date (select the exact date you want)
New Actions
Actions are configured in the plugin settings and add more options for the plugin.
  • Create Task Notes from tasks
    • Auto generates a note for each one of your tasks which use the default Obsidian notes
    • Your task notes now tie into Obsidian Graph with one click of a button
  • Auto generates a Project Planner folder to keep your task notes organized. You will be able to chose your own folder locations as well.
Tab management
You can chose whether you want plugin views to open a new tab or open in the same tab.
Of course there’s a lot of other improvements to the codebase, UI/UX and existing features.
It’s almost ready for beta release.
Bidirectional Markdown Sync
Currently testing out bidirectional synchronization between Project Planner internal JSON data storage and markdown notes in Obsidian vault.
## Task Markdown Format
Tasks are stored as markdown files with YAML frontmatter:
```markdown
title: Implement login feature
status: In Progress
completed: false
priority: High
bucketId: bucket-1
startDate: 2026-01-10
dueDate: 2026-01-20
tags:
  - frontend
  - authentication
dependencies:
  - FS:task-id-predecessor
This is the task description. It can contain any markdown content.
## Subtasks
- [x] Design login UI
- [ ] Implement authentication logic
- [ ] Add password reset
## Dependencies
- FS: [[Predecessor Task Name]]
## Links
- [[Related Design Document]]
- [https://example.com](https://example.com)
Settings
Added sync options to the plugin settings:
Enable Markdown Sync
Enables the bidirectional sync system. When disabled, markdown files won’t be watched for changes.
Auto-Create Task Notes
Automatically create/update markdown notes when tasks are modified in the plugin UI.
Sync on Startup
Scan project folders and import task markdown files when the plugin loads.
Sync All Tasks Now
Manually trigger a one-time sync of all tasks to markdown files (useful for initial setup or after bulk changes).
If you are interested in following the development progress of Project Planner, I welcome you to check out the following:
If you are brave enough to try the dev/beta version, you can install it using the BRAT plugin.
Latest update:
I am working hard to clean up and refine the code to ensure it runs efficiently and adheres to the Obsidian plugin guidelines. The most recent release version is 0.6.3 and I am currently working on the next release version 0.6.4 which will feature bug fixes, code cleanup, a little more UI/UX polish, and a couple new feature. Other than that, I’m testing all features and functionality on a daily basis.
Overall, Project Planner is stable enough to use daily.
Cheers - James
This has a lot of promise. I’ll give it a shot.
New development release 0.6.5 fixes several annoying bugs, most notably a bug that affected Obsidian Sync users.
Bug Fixes
  • Markdown sync no longer produces duplicate tasks when Obsidian starts. This bug affected users that use Obsidian Sync.
  • Project Planner no longer opens a new tab every time Obsidian starts.
Added
  • Auto generated Created date, ‘Modified' date for every new task. Unfortunately, tasks created in previous plugin versions are unable to have Created date autogenerated.
  • Grid view now includes Created date and ‘Modified' date columns with the option to show or hide.
Download the new version: Release v0.6.5 · ArctykDev/obsidian-project-planner · GitHub
View the full list of changes: https://projectplanner.md/changelog
A few screenshots of the different plugin views.
Hi everyone,
There’s been several updates to Project Planner since I last posted here. The plugin is currently on version 0.6.11 with rapid development currently in-progress to fix bugs, cleanup the codebase, improve current features and ensure full compliance with the Obsidian plugin guidelines.
Grab the latest releases: Releases · ArctykDev/obsidian-project-planner · GitHub
Project Planner news and documentation: https://projectplanner.md/
Improvements continue to be make on the Timeline view (Gantt view):
Improvements continue to improve Board view:
Major improvements have been made to Grid view:
Small improvements have been made to the Dashboard view. A lot more coming in future releases:
Major improvements have been made to plugin settings, including new features and better handling of existing ones:
Bug fixes, improvements and template updates for Markdown sync:
Thanks - James
Project Planner v0.7.0 — Effort Tracking and Auto-Scheduling
Version 0.7.0 is the biggest update to Obsidian Project Planner yet. This release brings three headline features that put it on par with Microsoft Project and Premium Planner: full effort tracking, dependency-driven auto-scheduling, and visual dependency arrows on the Timeline.
Read the full announcement: Project Planner v0.7.0 — Effort Tracking and Auto-Scheduling — Project Planner Blog
Install Project Planner: Installation — Project Planner Docs
GitHub: GitHub - ArctykDev/obsidian-project-planner: A beautiful, Microsoft Premium Planner style plugin for Obsidian · GitHub
This looks very nice. Just started testing version 1.0.1 and have a question:
How do you group tasks to make them show up under a common project in the Gantt-view by selecting “Group by: Project”?
Hi @JockeRad,
Are you sure this is related to the correct Project Planner plugin?
Obsidian Project Planner is currently at version 0.8.4 and by default tasks are grouped by project.
It’s been a while since I shared an update here for Project Planner.
The plugin has reached version 0.8.4 and has a lot of refinements and major improvements under the hood as well as some new features. Way too many to list here. If you’re interested, visit the links below for a full changelog.
The biggest new feature is the My Tasks view which is a Day/Week/Month view for tracking tasks across a project.
Markdown sync has been completely redesigned do allow better synchronization with Obsidian notes and other plugins.
Read more about these changes here: Blog — Project Planner
GitHub Repo: ArctykDev/obsidian-project-planner: A beautiful, Microsoft Premium Planner style plugin for Obsidian
Project Planner v0.8.5
v0.8.5 is out — reorder Dashboard project cards by drag-and-drop, set a default status for new tasks, and get an amber warning on Gantt bars when a deadline is approaching. Plus two bug fixes for cross-project task detail lookups and markdown sync watcher registration.
Full release announcement: Project Planner v0.8.5 — Project Planner Blog
Update via BRAT or download: Release v0.8.5 · ArctykDev/obsidian-project-planner · GitHub
