Obsidian pastes images which are different than the intended ones.
I copied a text which also contais images from Microsoft Word into an Obsidian note. Some of them were replaced by other images from the clipboard resulting in a duplication of some images and omitting of some other.
To paste all images as they are in the original document. E.g., if I have images (1, 2, …, 10) in that order then that should also be the pasted result (1, 2, …, 10).
The actual result is different though as it omits some images replacing them with others from the set, e.g., (4, 5, 6, 7, 8, 6, 7, 8, 9, 10). It even seems to paste images from texts from other notes, e.g., (11).
No, I can’t attach it as .docx files are not supported. “Sorry, the file you are trying to upload is not authorized (authorized extensions: jpg, jpeg, png, gif, woff, woff2, zip, css, md).” I also had to remove two screenshots, as you probably observed, because I am a new user and am limited to 5. I will upload them now.
I played around with the settings but nothing seems to solve this problem. To make matters worse, the mathematical equations generated by Microsoft Word are treated as images themselves when copied to the clipboard. This results in the pasting of many wrong equations where they shouldn’t belong. Since I accumulated a lot of information in office documents before I tried Obsidian, I can’t simply transfer every equation and image 1 by 1 into Obsidian, as that would require way too much time investment. Thus, if you don’t support the feature to paste something in its original form to the point of considering this a bug then this is a complete no go for me.
