- Install Obsidian (1.9.10, OSX 15.6 Sequoia)
- Attempt to “open folder as vault”
- Get spinning wheel, program not responding
This is not a problem with the default vault or the sandbox vault; but it makes it impossible to use with any other vault, or to create a new one.
A OSX Folder window
Spinning wheel and unresponsive Obsidian program
Obsidian version: v1.9.10
Installer version: v1.9.10
Operating system: Darwin Kernel Version 24.6.0: Mon Jul 14 11:30:40 PDT 2025; root:xnu-11417.140.69~1/RELEASE_ARM64_T8132 24.6.0
I’ve found a workaround which is to open the program from the command line, using sudo. So it looks like its a permissions problem inside Obsidian.
I’d already given the program “Full Disk Access” permissions, it still needs the sudo to work.
I’ve installed the program both with brew, and also by downloading the image directly; same behaviour with both.
