Obsidian on iPhone is taking 20 seconds to load 283 entries vault
Obsidian on iPhone is taking around 20 seconds to load a vault containing 283 files. Any way to speed up the loading? I have omnisearch plugin active. I turned it off but still there is no improvement in loading. It’s an offline vault. There is no sync setup.
Device Info
iPhoneSEII
iOS 15.5
Moved to help because you didn’t follow the bug report template and it’s probably not a bug anyway.
Follow the steps in About the Bug reports category - #11 by system
If none of that helps, try rebooting the phone.
It did not work. It’s taking time even after phone reboot. Anyway I moved away from Obsidian.
