Obsidian not displaying PDF's correctly
Import my Player’s character sheets into obsidian for quick reference during my games.
The PDFs dont retain the checkboxes, only the text in less important boxes.
1.) Deactivating my plugins and reloading
2.) checking for theme updates, none applicable
3.) tested other PDFs, same problem
4.) looked for similar issues and found basically nothing helpful
Images for context:
What im seeing currently -
What i should be seeing -
bumping cause i really need a way to fix this, it seems that the interactive boxes are rendering a white line for some reason instead of a black dot, nowhere else online has an answer for this issue
