Obsidian mermaid does not recognize treeView type
Use a treeView diagram as documented at TreeView Diagram (v11.14.0+) | Mermaid
Specifying diagram type in a mermaid codeblock as treeView as well as treeView-beta (as shown in linked documentation above); searched in forum and obsidian docs.
Based on other mermaid posts in the forum, I am assuming that the version of the mermaid lib in Obsidian is older than needed to support that diagram type, but it also looks from those posts like I can’t manually update that lib to test if that’s the case.
It’s not supported in Obsidian yet, but there is a plugin called Mermaid ELK Renderer that allows you to install the latest Mermaid and use it in Obsidian.
Thank you! I installed this plugin and it works like a charm!
