Not feeding data to AIs , only use a node data
Hi Mark. Your product looks wonderful, congratulations! On your github page, it says " This is not an open source project but lishid (obsidian developer) can check this code". Has your code been checked by an independent obsidian developer?
Thanks,
Jana
yes, my code has checked by an independent obsidian developer
Hi, I installed the pdfjs plugin, I was looking at docs, and tried to run it, but when I clicked “Annotate” what is shown in the screenshot appeared. (I can’t take notes from pdf files because of this, please explain why this happens)
I had the same problem as this.
I love this plug-in, I really want to try it, but I can’t get annotation of pdf. Should I subscribe?
Hey
I installed Markmind, purchased and pasted the code correctly, but when I click on Annotate PDF in the menu the following screen appears.
How to solve?
Hi, may I know how to solve the Active Code Error problem in the mobile version? I had bought the catalyst version and it works excellently in PC however, I met some problemw when I am using Tab.
Active code error
Hello, I’ve subscribed to markmind, however I noticed that sth is wrong. I use Markmind + Markmindtools. It still works to some extend, but I have some troubles with a few functions. F.ex. I cannot delate some nodes. I’m not sure which plug in poses this sort of troubles, and whether it has anything to do with the “Active code error”. I cannot f.ex. change the size of letters. That happened all of a sudden. Anyway, I wonder now what could be done with this ‘‘Active code error’’. I hope I could get some advice on that here!
I have same issue. It can’t work on Tab.
Hey Bro, can you add e-mail address for support ?
I have 3 questions :
1- If I buy 16 usd lifetime support, and move my vault with my plugin files into another computer that has not got any internet connection, is it works ? Or the rich type uses files from the internet ? From security reasons, that computer has not got internet.
2- In your website, there is only pay-pal option. Maybe you can add mastercard option so people that have not got paypal in their countries can buy your tool.
3-In order to write sth to you, I come here. And from my research, I find that many questions went unanswered.So can we say there is no support ?
