Type examples from the CommonMark spec, e.g. 250, 251, 112, 113, 116, 596
Yes
Rendered markdown that conforms to the CommonMark specification and matches the examples’ expected output
Rendered text that does not match the specification
For a qualitative idea of the error, (besides the list of wrong examples) I have noted the following issues so far:
- Nested quotes do not behave lazily, only the outermost quote block does
- Indented code blocks do not include spaces correctly
- autolinks are not parsed
There may be more, I have not exhaustively looked through the spec examples, nor the Github markdown spec.
