This is really frustrating. It’s happening constantly without any apparent reason.
I used Obsidian on a much older Windows machine with the same plugins installed and never had issues with Obsidian freezing.
Now, it happens constantly.
Has anyone encountered the same bug?
Pch
July 5, 2024, 8:24am
2
It potentially could be useful to add a bit more context to your question :
What’s your Obsidian version (and what’s the installer version) ?
Does it also crash with the Sandbox Vault (I mean, if you open the Sandbox Vault and enter fullscreen for that one) ?
When does the crash occur, more specifically ? (is there a note open when you toggle fullscreen, a canvas, … ?)
What plugins do you use ?
Does the crash occur if you’re in Restricted Mode (no plugin, no css snippet and using only Obsidian’s default theme) ?
Thank you for this detailed debugging roadmap!
The culprit was the Surfing plugin.
I love Obsidian and always try to consolidate my workflow within, but web browsing is not quite there yet.
The idea is great and I hope this plugin can get some maintenance and upgrades.
Pch
July 15, 2024, 12:13pm
4
My pleasure !
Glad to know it helped you find the cause of the crash!
I hope someone will give an upgrade to Obsidian surfing - or maybe this will be integrated as a core feature.
The ability to surf the web within Obsidian is a real game-changer, it allows to perform so many workflows directly from the tool we all love
system
Closed
November 28, 2024, 4:26am
6
