I do not know why Obsidian does not have Anchor link to jump at the designated location.
If you know how to create a Anchor link, please tell me.
So you are trying to link to the same note, correct?
You can use Block Links, just put a caret/hat in front [[^ and the note will popup a list of everything else in the note to link to. It will assign a number to the block. And you can still use the pipe command to add a word(s) into the link for that block.
Ex. [[#^b855fa | anchor link]]
The hashtag is added by Obsidian, but you don’t type that, or the number. Just type [[^ and scroll to pick the link destination. Then you can add the pipe and words if desired.
Got it. thanks a lots!
You are very welcome, please mark the reply as the Solution.
