Obsidian does not follow CommonMark indented code spec
Type the following:
        this should start with 4 spaces
    this is the start of a block
	which should continue here
	and trailing spaces should NOT be included
Yes.
the first line should be an inline code block starting with four spaces, not a doubly indented code block
The 2nd and 4th line should be part of the same code block.
the 5th line should not have trailing spaces included in the block
(in addition, each indent line is rendered as a separate block, though this may be intended behavior)
Obsidian version: 1.12.7
Installer version: 1.12.4
Operating system: #1 SMP PREEMPT_DYNAMIC Wed, 25 Feb 2026 23:12:35 +0000 6.18.13-arch1-1
I don’t think you are right in this case
I think copy-paste destroyed the formatting, and I should have put first and second line in separate blocks
To be clear, with . as spaces:
........this should start with 4 spaces
and for the second part:
....this is the start of a block
....which should continue here
You are right about the final part though i misread that.
PS: just noticed, this is another issue which is limited to the edit view, so yeah I was mostly wrong on this.
