Obsidian does not follow CommonMark autolink spec
Type the following examples in a file:
False negatives:
<irc://foo.bar:2233/baz>
<a+b+c:d>
<https://example.com/\[\>
False positives:
<https://foo.bar/baz bim>
<https://foo.bar >
<https://foo.bar     >
Yes
The false positives should be recognized as autolinks, and the enclosing brackets should not be rendered. (the latter is and invalid destination but still a valid autolink)
The False positives are not autolinks because space is not allowed inside links, and should there
The false positives are falsely autolinks, the false negatives are falsely not autolinks
Obsidian version: 1.12.7
Installer version: 1.12.4
Operating system: #1 SMP PREEMPT_DYNAMIC Wed, 25 Feb 2026 23:12:35 +0000 6.18.13-arch1-1
