Obsidian does not detect links to notes if HTML code is embedded in front of them
  1. Create a “note 1” note
  2. Create a “note 2” note
  3. Paste the html code into the “note 1” (for example, the html code of the YouTube video)
  4. Write a link to the “note 2” below
  5. Open the “note 2”
  6. Backlinks in document
  7. The backlink to the “note 1” is not displayed
  8. There is also no connection between notes in “graph view”
Yes
  1. There should be a backlink in the “note 2” file (we made a link in the “note 1” file)
  2. There should be a link between notes in “graph view”
This does not work even if:
<html code></html code>
some text
link
Obsidian could not detect the link due to the embedded HTML code.
If you make a line break between the embedded html code and the link, then everything works:
link
Obsidian version: v1.5.12
Installer version: v1.5.12
My example.
“note 1”:
<iframe width="470" height="835" src="https://www.youtube.com/embed/N_s_ZTeiXxE" title="wawa" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
note: [[note 2]]
“note 2”:
(empty file)
This is not a bug.
In Obsidian, you HTML block operators need to be in their own markdown block (separated by black lines) and can’t be intermingled with markdown.
This was in the docs but I can’t find it anymore. I’ll update the docs again.
