Obsidian Clipper: how to read {{highlights}}?
I am using Obsidian Clipper, and I am trying to write on the note the following content:
The code I am using is the following:
# Highlights
{{highlights}}
# Content
{{content}}
But instead of the markdown format of my highlights, I get:
        "text": "Selector variables allow you to extract text content",
        "timestamp": "2024-10-20T19:34:05.462Z"
        "text": "eturns text content of the first `h1` element on the page.\n-first `.author` element on the page.\n- ",
So, I want the highlights and the full content of the page.
I tried the two options at the Clip behavior, but does not allow me to get both contents at the same time.
So, how to I format the {{highlights}} in JSON format to a markdown format?
Thanks!
My environment
	Obsidian version: v1.7.4
	Installer version: v1.7.4
	Operating system: Windows 11 Pro 10.0.22631
	Catalyst license: insider
	Insider build toggle: on
	Snippets enabled: 4
	Plugins installed: 19
	Plugins enabled: 19
		1: Text Format v3.1.0
		2: Omnivore v1.10.4
		3: Templater v2.8.3
		4: Dataview v0.5.67
		5: Calendar v1.5.10
		6: Settings Search v1.3.10
		7: Homepage v4.0.6
		8: Text Extractor v0.5.2
		9: Omnisearch v1.24.1
		10: Natural Language Dates v0.6.2
		11: Mind Map v1.1.0
		12: Excalidraw v2.5.2
		13: Git v2.27.0
		14: Tag Wrangler v0.6.1
		15: Tasks v7.11.1
		16: Plugin Update Tracker v1.6.0
		17: Image Converter v1.1.7
		18: Enhancing Export v1.10.8
		19: CSV Codeblock v1.1.0
Microsoft Edge
Version 130.0.2849.46 (Official build) (64-bit)
Obsidian Web Clipper
Size: < 1 MB
Version: 0.9.4
The highlights variable is an object. So, you need to use filters to render them like you want.
For exemple, personnaly I render them as list like that:
{{highlights|map:item => item.text|list}}
Thank you! Works perfectly!
I just want to make another quick change… how to add an if so the highlights are not created if the lenght of highligths is 0?
Something like:
{% if highlights.size %}
# Highlights
{% endif %}
# Content
{{content}}
or
{% if highlights.length%}
# Highlights
{% endif %}
# Content
{{content}}
or
{% if highlights|length%}
# Highlights
{% endif %}
# Content
{{content}}
or
{{#if highlights.length > 0}}
# Highlights
{{/if}}
# Content
{{content}}
and combinations of lenght, size, . or | .
I have not been able to make it work.
Any ideas or things to try?
Thanks!
For the moment, there isn’t an if filter, you can’t have a condition in the template like that. Maybe it’ll be just later, it’s still in the beginning.
