It does, but it adds the folder - so if I try to make a link to [[note taking]], I am prompted to choose whether I mean [[Article/note taking]] or [[Notes/note taking]], as an example. I usually use CMD O to open up a page (I’m on a Mac), but if you’re using search, you can use double quotes to make a search for an exact term; i.e. "note taking" will only show notes that contain that exact phrase.
Interesting. My use case was a little different in that we were both using Obsidian, but only needed to share a folder that we could both read and write to. For that, I used Dropbox and shared just that folder with him. We’ve moved to using GitHub as you mentioned, mainly because we wanted others to be able to see it as well.
Since you want to be able to view, but not edit, each other’s notes, Obsidian doesn’t natively support that right now, but you could probably achieve the same thing by:
- Using Dropbox to set permissions: Share a folder, but add each other as viewers instead of editors. Then open up the folder as a vault in Obsidian, and either use the Obsidian URI to link to your vault to that vault or just make that folder part of your vault; or
- Consider using Obsidian Publish for certain notes that you want to make available. I believe there’s a way to password-protect your Published vault, although I’ve not tried it myself. Then, you’d be able to link to your coworker’s pages like you would webpages.
Hope that helps!
