How can I use the Text Generator to draft a text based on multiple specific documents in my Obsidian Vault?
I have tried {source: Documentname}
If the plugin is this one: GitHub - nhaouari/obsidian-textgenerator-plugin: Text generator is a handy plugin for Obsidian that helps you generate text content using GPT-3 (OpenAI)., you’ll want to read through their documentation for the setup steps: https://text-gen.com/
If you have it set up, maybe you could share a bit more of the steps that aren’t working for you. Someone may be able to spot something.
Thanks it’s working now. I guess the problem was the linked document
