I can’t get Minimal or the default theme to retain width settings with the Testflight build on an iPad. Close a note, open a note and the text width spans to the edges again. This is on a fresh vault with only the Minimal theme and Minimal theme settings to adjust width. Took a vid of setting up the fresh vault, but that’s a big file.
Please follow and include the bug report template when submitting bug reports. Thanks.
There’s a fix in desktop v1.5.10 that may be it. Obsidian 1.5.10 Desktop (Early access) - Obsidian
- Fixed readable line length not getting applied immediately when opening a tab.
If it’s this, we’ll have to wait a bit until this change comes to mobile.
