Disclaimer
Here’s how to make Obsidian mobile work as if it’s running on a tablet, even though it’s running on a smaller screened device like a smartphone.
const Platform = require("obsidian").Platform;
Object.defineProperty(Platform, "isTablet", {
get: () => true,
set: () => {}
Object.defineProperty(Platform, "isPhone", {
get: () => false,
set: () => {}
document.body.classList.add("is-tablet");
document.body.classList.remove("is-phone");
With this, you can now drag tabs to split them[1]. Restarting Obsidian makes everything go back to normal.
How you run the JavaScript is up to you[2]. Here are two options using the CodeScript Toolkit plugin:
Button in a markdown page
Paste this in any page. You’ll get a button that runs the script[3].
```code-button
caption: 'Tablet mode'
get: () => true,
set: () => {}
get: () => false,
set: () => {}
Invokable script
In CodeScript Toolkit’s settings, set an “Invocable scripts folder” and save this in that folder as a .JS file. You will then be able to run the script from the command palette.
exports.invoke = async (app) => {
get: () => true,
set: () => {}
get: () => false,
set: () => {}
Related feature request: Split Down & Split right command for Obsidian Mobile on phone - Feature requests - Obsidian Forum ↩︎
DataviewJS, Templater, QuickAdd… ↩︎
This is what I used in the example screenrecording. ↩︎
