Observed Beginner Failure Patterns — Proposal: Minimal Mode Onboarding
Over the past few weeks, I’ve been studying recurring beginner struggles across community discussions.
Three patterns show up consistently:
  1. Premature architecture — users build elaborate folder/tag systems before accumulating meaningful content.
  2. Borrowed workflows — users replicate templates or methodologies that don’t match their cognitive style or needs.
  3. Plugin escalation — friction leads to adding more plugins, increasing complexity instead of reducing it.
All three share a structural inversion:
Beginners optimize for sophistication instead of reducing capture friction.
High flexibility is powerful — but exposed too early, it can destabilize usage before habits form.
Proposal: “Minimal Mode”
An optional onboarding constraint that emphasizes:
  • Core functionality only (no plugin exposure initially)
  • Flat structure (no complex folder hierarchy upfront)
  • Capture + search as primary workflow
  • Gradual exposure to advanced features based on usage
The goal would be behavioral stabilization before architectural expansion.
Curious whether something like this has been explored before, or if onboarding friction data supports (or contradicts) this observation.
I agree with you general observations, but you should not forget the bias you probably observe when looking into forums and discussions.
Starting with Obsidian can be a struggle, as is any other software you are not familiar with. I think the issue is more general — there are some people who expect to get results without putting effort into learning something, while others first have a look at the documentation and guides to get started. The latter ones will not be equally represented in forums asking beginner questions, because they found their answers in already existing resources. There are so many low-effort posts across forums (in general, not only specific to Obsidian) on how to get started with something.
So I don’t really see the need for a minimal mode. Community plugins are off by default. Available functionality does not have to be used. You can start Obsidian, just type your first notes, and you are not confronted with a lot of the functionality.
The thing is, Obsidian isn’t a ready made point & click experience.
To use Obsidian with profit, beginners need first before anything else, learn what personal knowledge management is. There are books for this, a lot. Here an example
Second, they need to check out starter kits to see examples. Easy to find on this forum, with the search mask.
Third, work with minimum toolset to familiarize with basics.
Important note: Obsidian is no “fast food”.
That’s a fair point about forum bias — the people posting here are probably already the ones experiencing friction.
The pattern I was trying to understand wasn’t necessarily “Obsidian is too complex,” but why beginners often respond to uncertainty by adding structure early (folders, tags, plugins).
I’m curious whether the friction is more about tool exposure or PKM mental models.
For example, even if plugins are off by default, the visible ecosystem and community workflows can signal that complexity is the expected path.
So the question becomes less about simplifying the tool and more about stabilizing behavior early.
Do you think the current onboarding already achieves that?
I answer to your main points first, and add my thinking at the end if you are interested.
I think that polished vaults in tutorials and guides — which have grown over years!!! — raise the expectations of beginners about how their vaults should look after a short time.
Yes, definitely.
I think it is very hard to influence the behavior of people. Even if you restrict features early, what stops them from simply activating them anyway, because they’ve seen it somewhere and want to try it?
I think there is no real onboarding from Obsidian, and I also don’t think it’s needed. The documentation explains the basic features very well — and at the same time serves as a nice demonstration of what Obsidian can do. Nowadays, there are so many guides and tutorials available for beginners, which is simultaneously a good and a bad thing (polished vaults).
I think that today, when someone starts with Obsidian and looks for a tutorial, they are exposed to a myriad of videos, guides, and example vaults. This is good on one hand, because it can give a nice overview of features. On the other, they are presented with very complex vault structures (polished vaults), and beginners don’t see that this might have been years of work to build. Some are then disappointed that their own vault doesn’t look like this after one week. This can end in them putting too much effort into anything other than their notes. So, I think a lot of these beginner struggles come from exposure to polished vaults.
From what I have seen, the three biggest traps for beginners are:
  1. Trying to have an extensive vault structure before having many notes.
  2. Wanting Obsidian to be personalized and super nice looking right away.
  3. Installing plugins before even having a need for them.
And the answer to all three of these is: start taking notes first, and care about the rest later. The good thing about Obsidian is that you can change almost anything later with little effort.
The difficult part is how to communicate this core message to beginners. Maybe tutorials mention it somewhere, but the message is just overshadowed by everything else they are showing.
