[Obsdian Publish Help] Favicon not loading
I’m trying to add a favicon to replace the the default favicon
Website: mathandamatter.com
Tried adding favicon-32x32.png and publishing to obsidian. Sometimes if I keep the website open long enough it switches to the favicon I have selected
I want to load that favicon instead of swapping halfways through a user being the site
Note:
I also found anoter form similar to this, where they enabled logo on obsidian publish and adding their favicon to it. However I dont want the logo to appear on the top left, only appear on the favicon.
Solved
Solution:
Ereased cache folder and left it alone for approx 20 mins, then it fixed itself. Seem to have been a cache issue with it not easring the default icon
