Preview pane does not rendered numbered list with 2 spaces as indent (already set as the tab size in Settings).
This does not affect unordered list, though.
2
not a bug. this is the spec.
The spec?
@WhiteNoise
If you set the tab size to 2, you can compare that unordered list is rendered properly whereas numbered list is not.
spec = specification.
again, this is normal. this is how markdown works.
https://spec.commonmark.org/dingus/?text=-%20a%20%20 %20%20-%20b 1.%20a%20%20 %20%202.%20b
