Note Toolbar v1.5 is now available via Community Plugins!
- Search for Note Toolbar in Community Plugins
- GitHub: GitHub - chrisgurney/obsidian-note-toolbar: Flexible, context-aware toolbars for your notes in Obsidian. · GitHub
New Features
- Support for setting the position of a toolbar in two spots:
Below Properties= default, respecting styles (including “sticky” on scroll)Top (fixed)= fixes the toolbar to the top of the tab
- Folder Mappings:
/= map toolbars for notes that just live in the root folder*= apply toolbars for all of your notes (note that you can still override this with more specific folder mappings or the property)- Tip: Put this at the bottom of your Folder Mappings in order to make sure more specific folder mappings take precedence.
- Styling:
- Support for styling via the Style Settings plugin. See here for more details.
- A new
buttonstyle to make toolbar items look like buttons.
- Right-click anywhere in a (non-callout) toolbar for menu with a shortcut to Note Toolbar’s configuration
- Commands:
- A new
Open Settingscommand, for convenient access to your toolbar configuration - A new
Toggle Properties(and Open/Close Properties commands) to completely expand/collapse the Properties section:- When expanding Properties, the command also completely unfolds the Properties heading.
- Your Preference seems to stay maintained if operating within the same tab/window, while opening a new tab/window requires the command to be run again.
- Note that vanilla Obsidian remembers your fold preference on save (which includes Properties), though this only seems to work in Reading/Preview mode (at the moment?).
- Disclaimer: I’m considering feature as experimental, as your mileage may vary. Getting it to work within Obsidian’s boundaries took some experimentation. It may never quite work perfectly, but I do believe it’s an improvement over the built-in
Toggle fold propertiescommand.
- A new
Improvements
- Ability to search when selecting a File to link to in settings (thank you @LBF38)
- Better handling of displaying toolbars when switching tabs (thank you @mitchmeister)
Fixes
- Hide on mobile and desktop not working when both were set
- Hopefully fixes issue where Obsidian was being reopened for some users
- …and more.
