Note Snapshots: A clean per-note version control plugin that handles attachments
Disclaimer
Community Directory: https://community.obsidian.md/plugins/note-snapshots
I often want intentional snapshots for a select few notes. For example, keeping today’s version of a note, so I can look back on it in five years.
I have tried a few per-note version control plugins, but what I wanted turned out to be a bit special, so I ended up building my own. It would be great if it also solves your needs.
Why another per-note version control plugin?
1. A snapshot history that stays meaningful
Instead of diff, I often switch between snapshots to directly look at them. Most plugins I tried automatically take a snapshot on every restore. That is good as a safety net, but it makes this kind of back-and-forth restoring awkward.
Say a note has two snapshots, V1 and V2. Switching between them can leave me with a long list of snapshots, even though there are really only two versions.
Another situation is when I just want to discard edits and go back to a snapshot. However, that needs a restore, which leaves behind a new snapshot with those unwanted edits.
This plugin checks whether there is actually unsaved work (note text and embedded attachments). If there is not, it silently switches to the snapshot you asked for, no new entry added. If there is, it flags for your decision: take a backup snapshot first, or restore anyway.
2. Attachments are part of the snapshot
I sometimes replace the images embedded in a note as it evolves. With attachment-cleanup plugins like File Cleaner, an image that is no longer referenced gets deleted, even if it is needed by an old snapshot.
Say a world-building note embeds world_map_v1.png in V1, then switches to world_map_v2.png in V2. If I restore V1 later, it is wrong for the note to come back without the V1 map, or with the V2 map instead.
This plugin treats attachments as part of the note. They are captured alongside the text in the snapshot, and restoring tries to bring back the right version of attachments (see limitations at https://github.com/aphasialog/obsidian-note-snapshots#limitations).
Other features
Beyond that, I have tried to keep the plugin simple and low-profile. There are basic snapshot functions like annotating, locking, and diffing, but I do not plan to add fancier features like a snapshot heatmap.
I hope it can be something you trust and forget about, so you can focus on what is more important to you.
