Hi!
I’ve searched “Note links without graphview reference” here and in help but would’t find anything. Is there a way to link two notes without the “line” in a graphiew?
Example: I have note “Tolkien” to which I link notes “Hobit”, “LOTR”, “Roverandom” and “Silmarillion”. I want to link between the book-notes as well but I want to avoid that tangled net in which this will end.
I did found couple posts where similar issue was discussed. There is a workaround where you create actual link makrdown and instead of net link you use path. I am looking for native solution, quick when writing (asi with standart links) and one that updates with changes.
Thanks for your time and all the best!
