Note Is Completely Empty Every Two Minutes
Anytime I’m editing a note then switch to a different application or if I don’t type for a while, the content on the note completely disappears. The note is still there, but it looks like nothing was ever added. I can press CTRL+Z and it’ll bring it all back, but this happens so often (almost every two minutes) that it’s becoming a nuisance and is making me wonder if I should switch to a different app.
Hello, before posting, did your read the troubleshooting guide?
That sounds like either a plugin or because you have your vault stored in a cloud syncing tool that is causing some conflicts.
  • Please don’t post in bugs without following the template and providing all the info that is asked.
  • Try the troubleshooting tips linked above.
  • You can try pasting your “Show Debug Info” here, and telling us where your vault is stored, in case it’s a cloud issue.
