Note Composer: Using "move to top" of selected note will prepend extracted content above YAML metadata
Following this post I would like to again raise the issue that appending things via the core note composer plug in to a file messes up the files frontmatter which makes the functionality almost unusuable.
Proposed Solution
Append the text in the first line after the metadata
Reproduced, thanks. Moved to #bug-reports.
Hey, are there any updates on this? It is still happening to me in the current insider version. Just checking if this is supposed to be fixed.
This seems to be fixed with the new properties function now available to insiders.
