Note Companion: AI Transcription, YouTube Capture, and Smart Workflows for Obsidian
Note Companion is an AI-powered assistant for Obsidian that helps you capture, transcribe, summarize, and work with information faster, right inside your vault.
Whether you’re doing research, learning from videos, taking audio notes, or automating repetitive tasks, Note Companion brings powerful AI workflows directly into Obsidian.
:package: GitHub: https://github.com/Nexus-JPF/note-companion
:puzzle_piece: Plugin Page: https://obsidian.md/plugins?id=fileorganizer2000
:sparkles: What Note Companion Can Do
:clapper_board: Transcribe YouTube videos
Pull transcripts (with multi-language support), even for videos without standard caption tracks.
Supports fallback methods for videos with region restrictions or bot detection.
:studio_microphone: Transcribe audio & video files
  • Fast uploads for small files
  • Automatic large-file handling via pre-signed URLs
  • Supports recordings, voice memos, lectures, and more
  • Ideal for researchers, students, and capture-heavy workflows
:speech_balloon: Chat with your notes
Ask questions, summarize content, or generate new material using your vault context.
:gear: Supports multiple AI providers
Choose whichever works best for you:
  • OpenAI
  • Anthropic Claude
  • Google Gemini
  • Groq
  • Local LLMs with Ollama
  • Custom base URLs for self-hosted LLMs
:house: Self-hosting support
Run your own backend easily. The new SELF-HOSTING.md includes:
  • Docker setup
  • systemd service examples
  • PM2 configuration
  • Environment variable templates
  • Troubleshooting and security notes
Great for privacy-focused users and local-model enthusiasts.
Note Companion - Recent Updates
What’s New
Web Search for AI Responses
Enable web search capabilities to enhance AI responses with up-to-date information
Powered by OpenAI’s web search feature with automatic citations
Optional “Deep Search Context” mode for more comprehensive results
Perfect for research, fact-checking, and staying current with latest information
Expanded AI Tool Set (30+ Tools)
The AI chat now includes a comprehensive set of tools for vault management:
File Operations:
Create, delete, merge, and organize files
Bulk find/replace across multiple files
Export to PDF, HTML, or plain text
Metadata & Organization:
Extract comprehensive file metadata (frontmatter, tags, links, headings)
Update YAML frontmatter properties
Add tags to files (frontmatter or inline)
Analyze vault structure and get improvement suggestions
Content Management:
Get backlinks and outgoing links
Extract document headings structure
Create reusable note templates
Generate personalized vault organization settings
Search & Discovery:
Semantic search through your vault
Search by file name patterns
Get recently modified files
Open files directly from chat
Atomic Notes Generation
Generate atomic notes from your content
Break down complex documents into focused, single-concept notes
Each atomic note links back to its source
Enable in Settings → Experiments → “Atomic Notes”
Advanced Context Management
Unified context system with support for:
Files (@file)
Folders (@folder)
Tags (@tag)
Search results
Text selections
Lightweight mode for metadata-only context
Context limit indicators
Enhanced Search Capabilities
Deep search context option for more comprehensive web results
Semantic search with improved accuracy
Better integration between vault search and web search
Existing Features (Still Going Strong)
Transcribe YouTube videos - Multi-language support, fallback methods
Transcribe audio & video files - Fast uploads, automatic large-file handling
Chat with your notes - Context-aware AI assistant
Multiple AI providers - OpenAI, Anthropic, Google Gemini, Groq, DeepSeek
Self-hosting support - Full Docker, systemd, PM2 configurations
Meeting Recorder & Note Enhancement
Note Companion now includes a powerful Meeting Recorder feature that makes it easy to capture, transcribe, and enhance your meeting notes directly within Obsidian.
Record Meetings Directly in Obsidian
The built-in meeting recorder lets you capture audio directly from your browser’s microphone. Simply click “Start Recording” and the plugin will:
Record high-quality audio in M4A or WebM format (optimized for compression)
Automatically save recordings to your configured folder with date-based filenames
Show real-time recording duration
Handle duplicate filenames automatically
Recordings are saved directly to your vault, so they’re always accessible and backed up with your notes.
Discover Existing Recordings
The plugin automatically scans your vault for existing audio files and adds them to your meetings list. You can also manually trigger a scan to discover recordings you’ve added from other sources. The system tracks:
Recording date and time
File size and duration
Transcription status
Which notes have been enhanced with each recording
AI-Powered Note Enhancement
The real magic happens when you enhance a note with a recording. The “Enhance Note” feature will:
1. Automatically transcribe the recording if it hasn’t been transcribed yet (using OpenAI Whisper)
2. Generate structured content including:
Full transcript
Discussion points
Action items
3. Add embedded audio players so you can listen to the recording directly in your note
4. Merge multiple recordings - enhance the same note with multiple recordings, and all recordings will be listed together
The enhancement process is smart about preserving your existing note content and only adds new structured sections. If you enhance a note that already has enhanced sections from the same recording, you’ll be prompted before replacing them.
Smart Metadata Management
All recordings are tracked with comprehensive metadata stored in your vault. The system remembers:
Which recordings have been transcribed
Where transcript files are located
Whether recordings were discovered or created through the recorder
This metadata ensures the plugin can efficiently reuse transcripts and track the relationship between recordings and notes.
Workflow Example
1. Start a meeting - Click “Start Recording” in the Meetings tab
2. Conduct your meeting - The recording happens in the background
3. Stop recording - Click “Stop Recording” when done
4. Open or create a note - Open the note you want to enhance
5. Enhance the note - Click “Enhance Note” next to your recording
6. Review the results - Your note now contains a full transcript, discussion points, action items, and an embedded audio player
Perfect For
Team meetings and standups
Client calls and interviews
Lectures and presentations
Personal voice memos
Any situation where you want to capture audio and turn it into structured notes
The Meeting Recorder feature integrates seamlessly with Note Companion’s existing transcription and AI capabilities, making it a complete solution for turning spoken content into organized, searchable notes.
# Interactive Flash Cards Feature
Note Companion now includes a powerful **Flash Cards** feature that transforms any content into interactive study materials directly within your Obsidian vault.
## What It Does
The Flash Cards template uses AI to automatically generate interactive flashcards from your notes, transcripts, or any text content. Each flashcard uses native Obsidian HTML features (details/summary tags), so they work seamlessly without requiring any additional plugins.
## Key Features
**Smart Content Extraction**
- Automatically identifies key concepts, definitions, facts, relationships, and important information
- Extracts testable knowledge points: definitions, concepts, formulas, processes, dates, names, theories, and principles
- Creates 10-30 flashcards depending on content length and density
- Focuses on fundamental concepts, frequently referenced information, and easy-to-forget details
**Intelligent Organization**
- Includes frontmatter with total count, topics array, and creation date
- Randomizes flashcard order to create a varied, shuffled study experience
- Mixes different topics, difficulty levels, and question types together
- Groups related concepts with 3-7 main topics identified from your content
**Interactive Study Experience**
- Click to reveal answers - each flashcard uses Obsidian’s native details/summary tags
- Questions test understanding, not just recall
- Answers are complete but concise (typically 1-4 sentences)
- Includes context and examples when helpful
- Supports markdown formatting: **bold**, *italic*, lists, and [[internal links]]
**Native Obsidian Integration**
- Works entirely within Obsidian - no external tools needed
- Flashcards are stored as regular notes in your vault
- Supports internal linking to related concepts
- Fully searchable and organized with your other notes
## How to Use
1. Select any note or content you want to turn into flashcards
2. Use the Flash Cards template in Note Companion’s formatting options
3. The AI analyzes your content and generates interactive flashcards
4. Study by clicking each question to reveal the answer
5. Use the frontmatter topics to organize and find your flashcard sets
## Perfect For
- Students preparing for exams
- Researchers reviewing complex topics
- Language learners practicing vocabulary
- Professionals studying new concepts
- Anyone who wants to turn their notes into active study materials
The Flash Cards feature seamlessly integrates with Note Companion’s existing AI capabilities, making it easy to transform transcripts, meeting notes, research papers, or any content into effective study tools.
I cannot get this reliably working with Local LLM. I want to use Local LLM server and connect all my computers to it. Using openweb UI. Everytime I enter my local address 192.168.1.54:3000 I get a error to enter the API key in plugin settings. But there is nowhere to enter this API key. This plugin is very broken for local LLM use.
You’re hitting this because the plugin needs two things when using a local LLM from all your computers:
  1. Where to enter the “API key”
    The plugin calls it License Key. It’s in Settings → Note Companion → General (first tab), at the top: “Note Companion License Key”. Put any value there (e.g. local-self-hosted-key). The error is referring to this field.
  2. What the Server URL is for
    The address you enter (e.g. 192.168.1.54:3000) must be the Note Companion backend, not Open WebUI. The plugin talks only to the Note Companion server; that server then talks to your local LLM (Open WebUI/Ollama).
To get “all computers → one local LLM” working:
  • On the machine that has your local LLM (e.g. 192.168.1.54), run the Note Companion web app from this repo (see SELF-HOSTING.md) on a port (e.g. 3010 so it doesn’t clash with Open WebUI on 3000).
  • In that backend’s .env, point it at your LLM (e.g. OPENAI_API_BASE=http://192.168.1.54:3000/v1 if Open WebUI exposes an OpenAI-compatible API).
  • In the plugin on each computer: Advanced → enable Self-hosting and set Server URL to your Note Companion backend (e.g. http://192.168.1.54:3010), and General → set Note Companion License Key to something like local-self-hosted-key (with user management disabled on the backend, any key works).
So: the “API key” is the License Key in the General tab; the Server URL must be your self-hosted Note Companion backend, not Open WebUI directly.
Note Companion :television: New Feature: ScreenPipe Integration
Search your screen activity and meeting transcriptions from the AI chat. The ScreenPipe integration lets you ask the assistant about what you were doing on your screen—Chrome, Slack, Zoom, Obsidian—and get answers from ScreenPipe’s recorded content.
:sparkles: Key features:
  • Search screen text (OCR) and audio transcriptions from Note Companion Chat
  • Ask in plain language: “What was I doing in Chrome?” or “Search my screen activity from this morning”
  • Results grouped by app/window (Chrome, Slack, Zoom, Code, Obsidian, etc.)
  • Configurable time range and result limit in Settings
  • Runs locally: ScreenPipe on your machine, search triggered from Obsidian
  • No need to leave Obsidian to recall recent work or meetings
How to use:
  1. Have ScreenPipe running (e.g. localhost:3030).
  2. In Obsidian: Settings → Note Companion → Experiments → Integrations → enable ScreenPipe.
  3. Open Note Companion: Open Chat and ask about your recent activity or a specific app.
  4. The AI uses ScreenPipe’s data to answer and summarize what you were doing.
Perfect for anyone who uses ScreenPipe and wants to search their screen history and meeting transcripts without leaving Obsidian.
Note Companion 3.6.4 (2026-02-14) – Smarter ScreenPipe meeting detection
Note Companion’s ScreenPipe integration now detects meetings more reliably. It uses app name, window title, and browser URL, so in-browser meetings (Google Meet, Zoom, Teams, Webex, Slack) are recognized even when the app is just “Chrome” or “Safari”. The From ScreenPipe section on the Meetings tab will show recent meeting audio from the last 6 hours by default (configurable in Settings → Experiments).
In this release:
  • Meeting detection by browser_url (e.g. google meet url, zoom url) for in-browser calls
  • Default ScreenPipe time range increased from 2 to 6 hours
  • Same logic used in the Meetings tab and in chat when searching screen activity
Smarter Meeting Detection & Enhanced Audio Support
This release brings a major upgrade to the Meetings tab in Note Companion! Meeting detection is now much smarter, with improved grouping and filtering of meeting sessions from your ScreenPipe recordings. Audio handling is more robust, and you can now capture, organize, and enhance meeting notes with greater accuracy and context. The UI is also more responsive and accessible, making it easier to review and manage your meeting content.
Technical Changes
  • Meeting detection now uses advanced grouping logic to combine related meeting events into sessions, reducing clutter and improving accuracy.
  • Detection logic distinguishes between strong (URL/window) and weak (app-only) meeting signals, ensuring only real meetings are shown.
  • Support for new ScreenPipe content types (ocr+ui, audio+ocr) for broader and more reliable meeting capture.
  • Meeting sessions now include provider detection (Google Meet, Zoom, Teams, etc.) and show why a session was classified as a meeting.
  • Audio recording format now prefers WebM for better compatibility and reliability, with fallback to MP4 if needed.
  • Meeting session transcripts are merged and deduplicated for cleaner note creation and enhancement.
  • UI improvements: sessions are listed with clear titles, dates, and detection reasons; actions for enhancing or creating notes are more robust.
  • Performance improvements for fetching and processing large numbers of meeting events (up to 500 per search).
  • Accessibility improvements in the sidebar and meetings tab styling.
Hi everyone :waving_hand:
A fresh round of improvements has been rolled out to make Note Companion smoother and more reliable in day-to-day use.
This update focuses on overall stability and polishing the core workflows. Several edge cases that could interrupt longer sessions have been addressed, and performance has been improved in key areas so actions feel more responsive. You should notice fewer hiccups when running transcriptions, capturing content, or working through multi-step workflows.
We also made a number of small UX refinements to reduce friction and make the plugin feel more predictable during regular use. Nothing flashy — just steady quality improvements that should make the experience more pleasant over time.
If you run into anything unexpected or have ideas for what should come next, your feedback is always extremely helpful and directly influences future updates :folded_hands:
Hi everyone :wave:
A new Note Companion update (v3.6.12) is now available.
This release introduces a new capability in the AI chat: you can now create links between your notes directly from the chat interface. This makes it easier to connect ideas while you’re working with the assistant, without having to manually switch back to editing the note.
This version also includes a major style refresh across the plugin with a more modern and accessible interface.
Highlights:
Create note links directly from the AI chat
Refreshed UI and styling across the plugin
Various small improvements and polish
The goal is to make the AI chat feel more integrated with your vault and smoother to use during everyday note workflows.
As always, feedback and suggestions are welcome!
Do you have a compatibility version coming out for phone (iOS) and ipad? That would be super awesome!!
Really appreciate you asking — an iPhone/iPad app would be awesome. We have to be upfront: development on the mobile app is paused for now, so we can’t promise a compatibility release or dates. We’ll share updates if that changes. Until then, the iOS Shortcut path is the main option for working from iOS with Note Companion. More details on the Note Companion YouTube channel, unfortunately, no more links can be added in this thread.
Note Companion 3.6.13 - Smarter Web Integration & Smoother Chat Tools
This release brings a major upgrade to Note Companion’s AI chat interface, making it smarter and more capable than ever. You can now fetch and summarize content directly from web pages, right inside your Obsidian sidebar. Plus, we’ve improved the reliability and responsiveness of chat-based tools, ensuring a smoother experience when organizing and analyzing your notes.
Technical Changes
  • Added a new ‘fetchUrlContent’ tool to the AI chat, allowing users to fetch and summarize web page content directly from a URL.
  • Introduced a dedicated UrlFetchHandler component to handle web content retrieval, with clear status feedback (loading, success, error).
  • Improved tool invocation logic in the chat interface to prevent deadlocks and ensure tool results are processed immediately, making chat tools more responsive.
Note Companion v3.6.14 is live
This release introduces a new way to extract and organize your notes effortlessly.
You can now turn any selected text into a new note with automatic linking. Just select text, run the command, and it creates a new note while replacing the original text with a wikilink.
You can also trigger this directly from the AI chat using a slash command. It works even if the editor loses focus, thanks to improved selection tracking.
The chat experience has also been improved with better slash command handling and clearer feedback.
:rocket: Note Companion v3.6.15 is live
This release improves PDF imports and refreshes the overall interface.
:page_facing_up: PDF text extraction now preserves line breaks and paragraph structure, making imported content much more readable and usable inside your notes.
:brain: The reading experience is smoother overall, especially for longer documents.
:artist_palette: The plugin also gets a visual refresh with a cleaner sidebar and improved clarity across the chat and organizer.
:rocket: Note Companion v3.6.16 is live
This release focuses on improving the reliability and consistency of the AI chat experience.
:high_voltage: Slash commands are now more reliable, with better execution and fewer edge cases.
:speech_balloon: Chat interactions feel smoother and more stable across different workflows.
:brain: Overall, command handling is more predictable, making chat-driven actions easier to use.
:rocket: Note Companion v3.6.17 is live
This release improves stability and reliability in the AI chat experience.
:high_voltage: Slash commands are now more consistent, with fewer edge cases and better execution behavior.
:speech_balloon: Chat interactions feel smoother, especially during longer sessions or more complex workflows.
:brain: Command handling is more predictable, making AI-driven actions more reliable overall.
3.6.30 - Smarter YouTube Note Magic
Note Companion now brings a powerful upgrade to YouTube note-taking! You can instantly generate multiple types of structured notes from YouTube videos—including summaries, key concepts, Q&A, and timestamped outlines. The plugin fetches video transcripts, extracts metadata (like channel and publish date), and auto-tags your notes. All YouTube notes are now cleaner, with clickable timestamps and channel links, and sponsor segments are automatically excluded. These improvements make organizing and learning from YouTube content in your vault easier and more flexible than ever.
Technical Changes
  • Added four new YouTube note templates: summary, key concepts, Q&A, and timestamped outline, each with detailed formatting instructions and metadata extraction.
  • Refactored YouTube transcript fetching and formatting: now supports transcript sampling for long videos to fit formatting token budgets, and never stores raw transcripts in the vault.
  • Auto-extracts and links YouTube channel names and URLs in note frontmatter and body.
  • Clickable timestamps: [MM:SS] and [H:MM:SS] markers in notes are now automatically converted to YouTube deep links.
  • Sponsor and ad segments are automatically excluded from all YouTube-generated notes.
  • Inbox processing now classifies and formats YouTube notes more robustly, with improved error handling and user notifications.
  • Added comprehensive tests for YouTube context extraction, formatting, and post-processing.
  • Template restoration and management now includes all new YouTube templates.
