I have a catalyst license.
I have installed version 1.8.6 with the installer 1.8.4.
But, for some reason I cannot find, my installation is not being updated to 1.8.7.
I press “Check for updates”, but nothing happens.
- Restart the application
- Manually press the button
- Turn off and on the “Receive early access versions”
My system:
Obsidian version: v1.8.6
Installer version: v1.8.4
Catalyst license: insider
Insider build toggle: on
Snippets enabled: 4
Plugins installed: 15
Plugins enabled: 12
1: Calendar v1.5.10
2: Natural Language Dates v0.6.2
3: Tasks v7.15.1
4: Templater v2.9.3
5: Text Format v3.1.0
6: Git v2.31.1
7: Homepage v4.1
8: Settings Search v1.3.10
9: Tag Wrangler v0.6.1
10: Enhancing Export v1.10.9
11: Plugin Update Tracker v1.6.2
12: Dataview v0.5.67
Thank you for any ideas on what could be happening.
Thanks!
