Not able to render tables using spaced repetition/flashcard
I’m trying to make a flashcard with a table.
The image above doesn’t work as there can’t be a new line under the question mark. But for the table to render, it requires a line above the table
Is there a setting in spaced repetition that allows new lines to be included in the flashcards or it it not possible at all?
There’s an option to set a ending tag for multi-line flashcards
Settings → Spaced Repetition → Flashcards tab →
The last option
It’s empty by default, but you set anything for the end tag.
Alternatively, you can wrap the table inside a callout, which will ‘fill’ the empty lines
i.e.
> [!NOTE]
> | A   | B   |
> | C   | D   |
