None of the “Go to” shortcuts are working
  1. Open several note tabs.
  2. Try navigating using “Go to tab #” (Ctrl + #) or “Go to next tab” (Ctrl + Tab).
  3. Rebind the shortcuts (e.g., “Go to tab #” → Alt + #) and try navigating again.
Y
It should be able to switch directly between tabs or cycle through them using the assigned shortcuts.
Navigation does not work. Keyboard focus does not change/cycle for desired/next tab.
Obsidian version: v1.8.10
Installer version: v1.8.10
Operating system: Windows 10 Home 10.0.19045
Live preview: off
Shortcuts like “Focus on tab group left/right/above/below” and “Navigate back/forward” work as expected.
I can try on Windows tomorrow, but cmd 1, cmd 2, cmd 3, etc., are working for me to change tabs on macOS.
CleanShot 2025-06-24 at 18.53.10
Y
Everything works for me as expected. I also have Windows 10.
Maybe there’s a conflict somewhere? Do you use software like AutoHotkey? Did you edit registry by any chance?
The troubleshooting steps were linked in the bug report template; I’d try those again:
No conflicts, no AutoHotkey, and no registry editing.
I’ve tested setting CTRL + # to “Quick switcher: Open quick switcher” and from 1 to 9 works but, oddly enough, CTRL + 0 did not. I’ve closed all other apps on my machine besides Chrome and still nothing.
I had missed testing this in the Sandbox Vault, so I switched over to it and the shortcuts worked there. After that, I restarted the app and the shortcuts started working normally, except for the default Ctrl + 0 to open the Quick Switcher. I remapped it to Alt + 0 as a workaround.
Everything seems normal now, aside from the fact that I can’t use Ctrl + 0 for any shortcut — but that’s no big deal, all good! :blush:
