Because the settings panel obscures most of the window when it’s open, I’ve recently started opening it in a second Obsidian window (“Open current tab in new window” and then open Settings) as a workaround to better observe the effects of making settings changes. I’ve encountered this bug while doing so.
- Open a note in a new window.
- Open the settings panel in that new window.
- Scroll the settings panel.
- Change a setting (e.g., a toggle for a css snippet, font size slider, etc.).
- Switch over to the main Obsidian window.
Yes
Main window comes to foreground; settings panel in the other window remains at its current scroll position.
Main window comes to foreground, but the settings panel in the other window loses its scroll position (scrollbar jumps to the top).
Obsidian version: v1.3.7
Installer version: v1.3.5
Operating system: Darwin Kernel Version 22.5.0: Thu Jun 8 22:22:20 PDT 2023; root:xnu-8796.121.3~7/RELEASE_ARM64_T6000 22.5.0
Catalyst license: supporter
Legacy editor: off
- The scroll position only changes if you change a setting before switching windows. Otherwise, it remains where you left it indefinitely, regardless of how many times you switch between the two windows.
- This only happens if the settings panel is opened in the new window. If it’s open in the main window and a setting is changed, switching over to the new window does not affect the settings panel’s scroll position.
