I’m hoping someone here can help me.
I installed Obsidian as Snap on Arch Linux (running Sway if that makes a difference). The UI fonts are displayed as rectangles.
Any help would be much appreciated.
I’ve tried deleting the font cache and installing snap-store, as per some thread a saw regarding the same problem on a different snap. Did not fix my issue.
Aside from the fonts, the window you show doesn’t even look like obsidian. Looks like a file manager or something?!?!?
Thanks for the reply.
This is the window that pops up when I choose to open a vault from the start up screen. So yes, my file manager.
This is probably not some Obsidian bug, but some issue with snaps and fonts in general. I was hoping someone had encountered the same thing and had a solution for me.
I had this on Manjaro as well. Clearing the snap font cache helped, sometimes:
rm -rf ~/.cache/fontconfig
sudo fc-cache -r -v
rm -rf ~/snap/obsidian/common/.cache/fontconfig
…but in the end I went with the AppImage release instead. No font problems with that one.
