Nix code block has no highlight unless in wrapped in callouts
  1. Create a markdown codeblock in nix like this
let
  inherit (pkgs.stdenv) hostPlatform;
  mount_path =
    if hostPlatorm.system == "aarch64-darwin" then
      "/Volumes"
    else
      "/mnt";
in
  1. Wrap the codeblock in a blockquote with callouts/styled blockquote.
[!EXAMPLE]
let
  mount_path =
      "/Volumes"
    else
      "/mnt";
in
  1. Code block in quote block have syntax highlighting.
Did you read and follow the Troubleshooting Guide? [Yes/No]
Prismjs supports nix so there should be syntax highlighting for nix regardless of callouts.
No syntax highlighting for nix code.
Obsidian version: 1.13.8 (367)
API version: 1.13.8
Operating system: Android 16 (samsung SM-F946B)
Webview version: 153.0.8010.36
Catalyst license: none
This section was written in Obsidian first.
https://obsidian.md/help/syntax#Code+blocks
You’ll see PrismJS nix highlighting in Reading view and rendered contexts (within a callout here), so that makes sense; it isn’t a bug.
There are a few community plugins that aim to show syntax highlighting the same across the different views. You could try one of those.
