Since Obsidian introduced the ability to open new windows, I find that new windows (and tabs in new windows) lack a couple of my favourite Obsidian features:
Entering [[ doesn’t show autocomplete suggestions
Entering # doesn’t show autocomplete suggestions
Both of the above points work in my main/original Obsidian window and tabs in that window, but not in new windows and tabs that belong to those windows.
I guess this is by design, but I’d love to see the functionality for all windows.
I’m using the latest insider build of Obsidian (v0.16.3).
I guessed the behaviour is by design because it’s been there since when the ability to open new windows arrived. This could absolutely be a bug. I checked the forum for bug reports and other kinds of posts regarding this but found nothing; I (perhaps foolishly) assumed that others would have reported about this being a bug before me.
That’s true, it’s surprising that a bug that interferes with such a core feature wouldn’t be reported yet. Maybe something in your setup is causing it — do you see the same problem in the sandbox vault (found in the help menu)?
Aha! So the problem is probably a plugin — maybe one that hasn’t yet been updated to support extra windows.
Plugins don’t update automatically, so if you haven’t been updating them, go to Settings > Community Plugins, click “Check for updates”, apply them, and restart Obsidian.
If that doesn’t fix the problem, you’ll need to figure out which plugin is the problem. If there have any obvious candidates, try turning them off one at a time (restart Obsidian each time to make sure they fully unload). If you have a lot of plugins to check, you might want to use the Divide And Conquer plugin to help investigate.
Oh, thanks a LOT for your help! All plugins are updated, so I’ll check them all later today to try and find the problematic one. Also, thanks for suggesting the Divide And Conquer plugin. I’ll report back.
Autocomplete works for me in the sandbox vault, both in the main window and in new windows (and tabs) as well.
Autocomplete doesn’t work for me in my regular vault.
I just tried to open another vault that I have, one that I’ve created, and autocorrect works on that vault, both in the main window and in new windows (and tabs).
Seems like something is wonky with my main vault, then! Hmm. I wonder if there’s some setting somewhere that messes something up. I’ve used this vault for just over a year now.
