I’m trying to figure out how to get new windows to open with the same theme/appearance settings as my normal window. I would’ve thought these would be global? Maybe I’m just missing something.
Searching for relevant settings, closing and reopening Obsidian, changing theme setting in new window (strangely it then applies the theme to the original window as well)
Open documents in new windows with the same theme settings as usual.
They should just do that without any effort.
Do you see the same behavior in the Sandbox Vault?
Thank you! Didn’t realize that.
Looks like I’ve gotten rid of the sandbox vault at some point, so not sure.
Trying it with different themes, it seemed to happen with some and not others. Mainly I use the Minimal theme.
How did you get rid of the sandbox? When you go to the Help menu and click Open for the Sandbox Vault, what happens?
Do you see the same behavior with Settings
> Community plugins
> Restricted Mode
turned on?
I’m using the Minimal theme, too, and not seeing the behavior you described (altho Minimal has about a thousand optional settings, so who knows).
